Triton46
- August 11, 2000
- Greensboro, NC
- 1991 Ford Explorer Sport
With 110,000 on the clock I found that the reservoir for the radiator is low. Not extremely low, but low. The last time it was filled was about 2 months ago (the dealer overfilled and I had to drain).
It is possible that I drained to much, but it has got me thinking. If I did have coolant leaking into the engine (burning it off), what would be the progression of events?
Obviously more would leak/burn...but could the leak be fixed without a major rebuild? What happens if I let it go (cracked heads, hydro lock, etc)? I am currently in need of a lower manifold gasket repair. My mechanic has offered to replace the lower and upper gaskets as well as the valve cover gaskets during the 'operation'. Could the leak be fixed here?
I'm wondering where a typical coolant leak occurs and if its something easily replaced during what I have outlined above. These types of discussions usually lead to "well while you're at it you should...", just trying to get a feel for what needs to be done. I am planning on rebuilding the engine (depending on condition) at 200,000k.
