Bulldozer
- November 6, 2011
- Calimesa, CA
- 1993 Explorer 4x4
A4LD 1st 2nd And Reverse Work, No 3rd or 4th.
So I just replaced my A4LD with a junkyard trans that had been recently rebuilt. Upon the first installation we mis-stabbed the torque converter and broke the inner pump gear.
Took it all apart, swapped in the pump gear from my old trans, took it to a shop to have them align the pump and he confirmed the pump was working and good to go. I bolted it all back up threw on a new torque converter (definitely properly seated this time!) and reinstalled the trans.
I added 1/2 a qt. of fluid to the TC before installation. The transmission was completely drained before installation, and I put in a new filter, new cooler and lines, new governor etc.
Before starting the truck I added 5qts. of fresh fluid and started it up, let it run for a couple minutes, fluid was barely on the dipstick so I added 1 more qt, it got up almost to the bottom of the hash marks, so I added another, all the sudden its 2 inches above the mark on the dipstick.
I cycled it through all the gears slowly with the rear wheels off the ground and everything was looking okay, except the fluid level would not drop at all, I thought this was strange as a dry trans should take 10-12 I've read. So I take it for a quick test, Reverse works perfect. If I put it in D or OD it feels like its taking off in 2nd but will NOT even try to shift to 3rd. If I manually select 1st it works, manually shift to 2nd, goes right in, but I manually shift it to D or OD and its like neutral. I probably drove it for a total of 5 minutes and the fluid temp never got over 100F, but the level never dropped.
SO I decided I would check if the pump was running,pulled the cooler "Pressure side" line and a couple ounces of fluid came out, I stuck it in a clear bottle and started the truck for a minute, NOTHING.
This makes no sense to me. Is it possible that the pump failed after a couple minutes but somehow some gears still work? Could there be a different problem? Maybe something wrong in the valve body or I somehow screwed up the the filter o-rings?
I'm praying I don't have to do this job a 3rd time.
Any advice would be greatly appreciated, thanks guys.
Oh one other thing, I reused the Bellhousing to pump and bellhousing to trans gaskets if that makes any difference.
