wood1
- May 3, 2007
- North of Edmonton
- '93 XLT, Cayman Green RIP
OK, so I am far from an expert on the D35 TTB but every time someone does a thread on modifying theirs I get all excited and start thinking about what to do with my own.
In the past few years I have collected quite a few links in relation to the TTB in the 1st gen Ex and I’m pretty sure lots of other guys have too. I would like to pool all our collective knowledge for easy access.
This will be a database of 1st Gen TTB links, grouped together so you can find what you want quickly. Rick suggested it be in this forum and that made better sense than putting it in the TTB It’s For Me social group.
Steering linkage:
Stonecrusher Experimental Steering
Offset TREs w/Stonecrusher Steering Setup
Broken Steering Shaft
Drop Pitman Arm
TTB Steering Info
Saginaw Pump Upgrade
Steering for lifted TTBs by Rusty
BillaVista's Hydro Steering
Saginaw Hydro Assist by BillaVista
TTB 101 by 4X4junkie
Examples of Swing Style Steering
Upgrade factory pump by Tbars4
Lifts/shocks/springs:
Maximum Flex with Jeep Coils
Lift Reviews
4X50 Explorer's F-250 shock mount
F-250 Shock Mounts
James Duff lift
Tbars4 (The Squirrel) Lift
The Quest For Droop, or Yellow Lab Drives 1st Gen
F-150 Coil Seat
Drop Brackets. What to look for
Optimizing the Skyjacker
Washer Coil Spacer
Not the average lift question
Naasau's garage art
Spring discussion
Radius arms/beams:
Broken/Cracked Beam?
Cut & Turn
Zimmerman's Rig
4 Link TTB
Extended Radius Arms
Cut & Turned Beams
Beef Up Your Beams
Knuckle swap, brakes, hubs, spindles/bearings:
D44 Knuckles on D35
Brake Line Positioning
'95-'97 Ranger Brakes On 1st Gen
Manual Hub swap
Another D44 Knuckles on D35
Auto & Manual Hubs 101
Stronger Jeep Manual hubs D35
Securing Hubs To Rotor
Wheel bearing issues
Auto Hub Washer Fix
Axle/driveshaft modification:
U-Joint Snapring Upgrade
C Clip Eliminator
Rebuild That Double Cardan
Double Cardan Joint Rebuild
U-Joint 101
C-Clip Eliminator by Tbars4
TTB binding issue
RCV axles for the TTB?!?!?
U-Joint identification
Gears/lockers/differential:
D 35 TTB Durability
Front Diff Removal
Limited Slip D35
Lockers
General info gear set-up
R&R and Locker install
Speedo gear color codes, formulas, part #'s
Drain plug for front diff by The Junkie
Gears
Diffs, lockers
Lockers
Is it a selectable locker or is it a LS?
Flip Truetrac gears
Good conversation on front LS or locker
Speedo Drive Gear Primer
Alignment
Alignment for TTB's
Camber bushings
Wheel alignment 101
TTB Camber
Camber shim info
Camber bushing replacement
More on alignment
General information/parts:
TTB General Info
How TTB is supposed to work by 4X4junkie
Get the most out of your TTB 4X4junkie
D28/D35 TTB Specs
Chrome moly outer axles!
D44 TTB
The flexiest TTB
Driveline 101
Hybrid vrs. true D35
glfredrick's 10 step program on how to build an Ex
Misc mods/build threads:
TTB limiting rig for hill climbing
DeRocha's TTB rebuild
1350/1354 doubler or double your pleasure, double your fun
How to install different gears 8.8
Kevlar clutch plate for the Ex
I will add your links under the proper heading as you post them to the thread so that they are easy to find.
Obviously my thanks and credit to the other forums that have threads listed here such as TRS, Pirate, Great Lakes and others.
If you find your thread here and want credit or want the link removed please let me know.
Steering linkage:
Drop Pitman Arm
TTB Steering Info
Lift Reviews
F-250 Shock Mounts
James Duff lift
F-150 Coil Seat
Washer Coil Spacer
Naasau's garage art
Spring discussion
Radius arms/beams:
Cut & Turn
Zimmerman's Rig
4 Link TTB
Cut & Turned Beams
Beef Up Your Beams
D44 Knuckles on D35
Manual Hub swap
Auto Hub Washer Fix
C Clip Eliminator
U-Joint 101
TTB binding issue
D 35 TTB Durability
Front Diff Removal
Limited Slip D35
Lockers
Gears
Diffs, lockers
Lockers
Flip Truetrac gears
Alignment
Alignment for TTB's
Camber bushings
Wheel alignment 101
TTB Camber
Camber shim info
More on alignment
TTB General Info
D28/D35 TTB Specs
D44 TTB
The flexiest TTB
Driveline 101
