- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
I was looking into all of the new kinds of seals that they now make for the low/reverse servo piston. So far as an alternative to O-rings, they now make single, and double lip seals, and viton seals. I think the Superior valve body shift kit uses the single lip seals (please correct me if I'm wrong). There are 2 other kinds that are available without an entire kit from WWW.TransmissionPartsUSA.Com. There is the double lip seal, and the viton seal. When I asked the salesperson, he said that he couldn't recommend any specific ones, because he personally never used them. He said that the shops use the standard rubber O-rings that come in the kits. I wonder which style is the best out of these 4. I was also looking for the thicker (.015") A4LD valve body gaskets. I used to be able to get them a few years ago from a local supplier until he closed down. I haven't been able to locate anybody else that sells them.
