CiDhed
- May 7, 2008
- 93 XLT 4X4
Ok. I have a 1993 Ford explorer that I put a A4LD out of a wreaked one in because the original had lost all gears and could only be moved while the Explorer was in 4wL.
Yesterday I was driving at about 50mph and pressed the gas enough to cause it to downshift and at that point I noticed the RPM's rise abnormally. The transmission had slipped. Shortly after that I caught a red light and when I went to pull away I had nothing. Not first, second, drive, OD or reverse. I put it in 4wL to see if that could get it to move and it didn't help. Fluid is smells fine and is at the correct level. I have put more then 500 miles on this since I put the 'new' transmission in. It was shifting and driving perfectly before this incident.
So I get it towed. After I get it off the back of the truck I start it and try it again and it goes into drive and I was able to pull it into a parking spot. I try reverse and that worked also. However, when I placed it back in drive it was gone again.
I plan to drop the pan tonite or tomorrow to see if there is any evidence of it self destructing.
Can anyone give me any hints on what I may want to look for? I just find it odd that it isn't making any noise. If the pump was bad or the filter was clogged then it would whine right?
:Edit:
Forgot to add that you can feel it engage into drive and reverse. At first I thought it might be the transfer case but then it wouldn't stay still in park.
:Edit:
