patmorrison
- March 23, 2004
- Anaheim, CA
- '92 XLT
ok, so im trying to measure endplay on the front end of the transmission, and Im having big problems getting the pump to fit into the bushing on the overdrive drum. The pump seems to get wedged into the bushing and not want to go in any further. Im begining to think that I may have put in the wrong replacement bushing in the overdrive drum. Can someone tell me if the pump normaly slides on into the center of the OD drum?
This may or may not have anything to do with it, but i found that the rebuild kit has a bushing that I cant find anywhere on my transmission. Maybe its the wrong kit with the wrong size bushing? Does the a4ld use different fundamental parts for different engine size applications?
Thanks!
Thanks!
