A4LD Reverse Problem | Ford Explorer Forums
WV Hillbilly
Pennsboro , WV
1985 Ranger 4X4 with A4LD transmission , 2.8 V6 engine & manual lever in floor for 4X4 & Hi & Low range . Transmission seems to shift & hold properly in forward gears . With transfer case in Hi range & the truck on the level or a very slight incline reverse works as long as you are easy on the gas . If on a steeper incline or if you goose the engine reverse lets go & just slips .
With the transfer case in Low range the truck will back up steep inclines & will spin the tires without slipping . I would think if it has a pressure problem or worn clutches or bands causing the problem that it would also slip in Low range before spinning the tires . Fluid has been changed & is at proper level on the dipstick . What do you think ? TIA
Greets,
Just in case you are still out there....;-)
I was having the same issue before my pump gear broke.... but that's a whole 'nother story;-)
Sounds like the Low Reverse servo might be leaking...if so you can fix it pretty easy..
Check the reply on this from Opera House:
http://216.189.1.23/forums/showthread.php?t=61579
Let's Go.....Mountaineers!!
Respects
Ragga
