greenmachine89
- May 25, 2008
- Battle Ground, WA
- 1991 XLT
Well I put my engine back in after changing all the seals and gaskets and now my tranny doesn't shift. I did take the pan off and change the filter along with new fluid in the tranny and TC. So I took a look at the vacume lines and found that the one on the side of the tranny was disconnected. Plugged that back in and still no shift, al it does is go into park. So looked around the site and found a few ideas so I decided to take the pan off along with the VB and found a mess! Sludge built up everywhere! I just bought this 91 Ex with 170,000 miles and I think the fluid was never changed! So now that I have the VB off I checked the Z link and thats not bent so no worries there but the VB what should I do? Clean it? If I do how should I go about doing that? Is there rebuild kits for the VB? I know a new gasket set is going to be needed, is the gaskets included in a rebuild? Should I look at anything else or just the VB? Help I'm down a car and all I have is a chop top B2 which you can't really put a kid in that!
