ABS and Traction Control with Weak Horn: Related? | Ford Explorer Forums
benman
Pittsburgh, PA
2007 Mercury Mountaineer
2007 Mountaineer awd premier v8
A few months ago, I started having the ABS/Traction Control/Wrench light issue that others have talked about here. It was intermittent -- only occasionally. At the same time, I noticed that sometimes when I locked the car, the horn sounded weak, like it was being smothered with a pillow.
Long story short: through luck and trial and error, I found that the horn was weak when the ABS and Traction Control lights came on and worked fine when those lights were off.
I did check the tone rings on the back -- no problem. I never did look into it further since it was intermittent and I couldn't find anything conclusive on here.
Now the dash lights and weak horn are a problem all of the time.
Can anyone think of a reason these issues would be related? I was wondering if they shared a ground and that was an issue, but I don't know where to look. It has warmed up here for a day, so I thought I'd look this afternoon.
How old is your battery? A weak/old battery can cause all kinds of weird, unrelated electrical gremlins.
Battery is only 2.5 years old. Would checking output with a multimeter find if it's a problem that would cause such things?
Stop by Auto Zone, Advanced Auto, or some other chain auto parts store and ask them to run a free electrical system diagnosis. It might tell you if the battery or something else in the system is bad.
Sounds like a ground issue....
Watch this,
