superboat
- September 14, 2010
- longisland newyork
- 1997 AWD mountaineer
whats going on guys,i got another issue with my truck.2006 awd mountaineer.here is what happened,driving to work last week and the abs and traction light came on.they would go on and off randomly i cant make it happen every time.twice i had the tires lock up on me pulling out of my driveway.i hooked a scanner up to it that i had at work and got a few codes.ill post the codes numbers tomorrow i left them at work,but i believe that the codes were for the front right sensor for no signal or circut.i have a live datastream on the scanner when i drive i can watch the mph coming from each sensor and they all are the same speed untill i make a turn and they change 1mph differenceso that makes me think the sensor is working fine??.next thing i ohm'd out the two front sensors and got 1.285 or 12.25 ohms for the front left.front right was .256 or 0.25 ohmsnow being that the ohms are that far off idk if that might have something to do with it also..fuses are good too.so im thinking it might be in the abs module but not sure?any help from you guys would be great ill be taking a trip down south soon and kinda need this fix asap,thanks guys.
