dburney
- May 9, 2022
- Denver, CO
- 2002 Ford Explorer 4.6L
based on my research in other forums and other posts similar to mine, sounds like the general consciences is 1) the ground wire to the transfer case shift motor (can't be this as the ground wire was brand new along with the new motor just installed) or 2) the module. New module comes in tomorrow and will be installed. I will update this post with the results in case someone else stumbles on this thread
I have also seen some feedback of the ECU but I am really hoping this isn't the issue and praying the module will fix my issue. Just to run through it all again... ABS 4x4 high (this light is flashing) and the advtrac warning light are on. No codes pulling from the ABS light (they were able to pull the check engine light which appears to be a pressure sensor for gas, another issue I will be dealing with) So I really am just trying to run through general diagnostic steps. As I have gone through replacing every sensor related to ABS and no codes are pulling, I am moving on to 4x4 and advtrac trouble shooting which is why I am at the module now. From my understanding, the module controls these things although, I am sure there are other parts that are related. If anyone has any other tips or tricks of what fixed your related issue, I am all ears. But not looking for general mechanic-y advice. Looking for a solution to my actual issue
