ABS light | Ford Explorer Forums
ABS light
stew17
Bel Air, MD
'93 Eddie Bauer
Alright, I have a 1993 Eddie Bauer Explorer and my abs light on the dashboard comes on now and it never did before, I've had the truck for two years. The brakes still feel the same when I slow or stop, but there is a slight shudder in the pedal, the car doesn't shudder just the pedal. What is the problem here and how can it be fixed?
Any help would be great, thanks
Stew,
If the ABS light is on, see if you can pull the codes using the information in this thread:
http://www.explorerforum.com/forums/showthread.php?t=258803
That should get to started in the right direction.
My problem ended up being in my one of the valves in my pump - had to replace it.
Then it ended up happening again. What's the odds of that?
Good luck!
happened to me all i did was bleed the brakes (front and back) and it fixed the issue hope this helps
