ABS module won't stop! | Ford Explorer Forums
kirkbs
North Carolina
2004 XLT
Just got back from a quicky lube place and the ABS light is on with the ABS module running even when the ignition is off. Of course, the lube place has "no idea" what could be wrong. My mistake for taking the easy way out of a summer oil change.
Disconnecting the battery and trying to reset the computer did not work.
Can anyone help? And by the way, wife is +1 day past due date...I'm in a pickle!
should be a fuse or relay you can pull, i don't know it off hand which will turn it off.
What did they do to your truck?
That's MY question! This is the LAST time I hit one of those Jiffy Lube places. Sucking it up and doing it myself.
I pulled the fuse...not the fix, but at least the motor stopped. I might go check my local junk yard for a new ABS module. I've been reading on other sites that this might be the problem (link below). As for now, we're riding without ABS.
http://www.2carpros.com/forum/abs-p...ous-even-with-no-key-in-ignition-vt48177.html
