ABS Problem - Please help | Ford Explorer Forums
morphous
Valparaiso, FL
97 Explorer Sport
I am really hoping someone can help me. I have this problem where the ABS kicks in when I am slowly rolling to a stop. Doesn't do it at high speed, just anytime 20mph or less. I thought... umm.. I replace the front two abs sensors and just clean up the hub. Well, that didn't correct the problem. I didn't replace the rear ABS sensor in diff but I'm not sure it the problem now. I bought new sensor from FORD. Is it possible they are bad?
Again, thanks for all the help.
Are you getting a warning light? The abs in my 94 did this on occasion. I had a constant abs light on the dash. After cleaning/replacing the sensors still had the light and problem. It turned out to be the relay.
Do a search on the board for this problem. Pulsation slow speeds or something similar. This seems to be a common problem.
-Drew
Thanks for help.
