ABS Problem | Ford Explorer Forums
ABS Problem
PabloMike
El Paso, Texas
2002 Ford Explorer XLS
I have noticed over the past 3 weeks that when I'm braking the brake pedal pulsates, I disconnected the ABS sensor form the front driver side hub assembly that I replaced today, and it doesn't do it anymore. Any ideas?
Disconnect your battery for a good while and reconnect the ABS sensor. Then reconnect the battery. If that doesn't work find a mechanic that can pull/clear ABS codes.
Thanks Brian, I'll give it a try.
