ABS sensor change? | Ford Explorer Forums
ABS sensor change?
lee83
97 explorer
i need to change one of the front ABS sensors on my Explorer. is this a easy job to do? is there a good web link with step by step info?
the abs ring that you are talking about is built into the the bearing and hub assembly. i just had to do one of mine too.
the sensor can be changed separately but the tone ring is part of the front hub a hub comes with or with out the wire sensor to change the sensor you must remove front brakes,rotor and backing plate the sensor some times gets stuck in hub be careful if you snap off end of sensor you may damage the hub trying to get it out
