blacknblue
- November 9, 2011
- Yuma, AZ
- 2003 Ford Explorer XLT
First off this is my first actual post. I have been lurking around since I got my Explorer a month ago. This site is a definite life saver as I have already found the problem with my cruise control not working properly, bad brake switch. Anyways onto my next problem.
My Truck
2003 Explorer XLT 4.0 V6
The Problem
So as the title states my A/C works great but my heat not so much. After the truck gets to operating temperature I try to get the heat going but it never really gets past luke warm. If I go full blast with it then it goes back to being cold. I have noticed that my temperature gauge will creep up enough that the "Check Gauge" light comes on but it quickly falls back down to the normal range. When it jumps up there I can turn the heat on and it comes out nice and toasty but only for a couple seconds.
Initial Thoughts
Now since I have been lurking around I have seen the articles with the blend door actuator but I lack some of the symptoms like the clicking that I have read about. Like stated above the heat works at times but only briefly or just barely. Could this just be the early onset of the blend door actuator going out or something else that I have missed?
Thanks for any help that I might get.
Dustin
My Truck
The Problem
Initial Thoughts
Dustin
