ac charged----> low idle | Ford Explorer Forums
expo5.0
Red Wing, MN
1996 xlt
i charged my ac and it made my truck idle badly and it still doesn't cool real well.
why the heck would it affect the idle
My first guess would be the IAC. Thats the piece that regulates the idle...
It is possible that the IAC isn't working and that when the a/c had a low charge that the A/C compressor never really turned on.. (there is a low cut-off switch to turn off the compressor if the pressure gets too low).. Now that the system is charged the a/c compressor is turning on and staying on and without the IAC to lift the idle when the a/c is on, it idles low.
Easy way to test the IAC.. Turn on the a/c.. unplug the IAC.. if the idle drops, then its not the IAC (at least it is working somewhat).. If the idle doesn't change at all, the IAC isn't working.
~Mark
thanks- i'll check that out tomorrow- that sounds pretty likely.
