AC clutch air gap spec | Ford Explorer Forums
My94Explorer
Mount Holly, NC
1994 4x4 Explorer XLT 5sp
I'm changing the AC clutch and pulley on my 1994 Explorer and I'm looking for correct spec for the air gap. I watched a video for Ford trucks in general and they said that .20 to .30 of an inch. Does anyone have the actual Ford spec for a 94?
I have searched the forums here and I got no results returned. I know that someone will reply to use the existing shim and that might work, but I would like to have the actual Ford spec.
Thank you in advance for any help you can give.
That's a good question. you have FS10 compressor
The spec for your air gap 0.35 to 0.85 mm (0.015 to 0.033 inch); the 8 mm nut is torque to 8 to 10 #/ft.
Check the clutch before putting it in service.
