pcovell74
- January 16, 2017
- Houston, Texas
- 2006 Eddie Bauer 2WD
OK, So I have an 06 Explorer 4.0 that quit blowing air out the AC/defrost heater, etc. I went ahead and checked both the 40am fuse under the hood and I swapped the relay to tested. I also checked the fuse under the drivers side. I swapped out both the fan motor and resistor. Still nothing.
Aside from manually changing out the external control knob, Is there anything else I can check to see what is causing the trunk to not to blow air?
