AC/heat 4th fan speed not working | Ford Explorer Forums
aj213121
Sport Trac '03 XLT
Hello, the 4th speed for my fan on my heat/ac is no longer working. Speeds 1-3 work perfect. I replaced the blower motor resistor already and just trying to figure out what's next to look at.
Thank you.
As it wasn't the blower resistor it might me the fan that switch is bad.
I had to replace the connector on mine. The connector on the resister. Was a couple bucks off eBay. Mine was pretty melted and corroded. Sounds about like what you got going on. Highest amperage draw setting can’t pull enough amperage through the dirt connection
Yeah i replaced both the resistor and connector...sorry forgot to mention that
Switch panel is the only thing you got left then. At least they are one of the easiest things to get at a junkyard just need a 7mm socket
Replaced the switch along with the connector. Still no 4th speed :(
