lww1142
- May 26, 2020
- St paul
- 2006 Explorer XLT
So I have the issue when I first fired up the AC this year that it is only blowing hot air. I know the compressor is on and kicks in when I turn ac on. I tried recharging the AC, but that was not needed and PSI level was in normal range. I believe the issue is just the blend door for the temperature control is stuck on the hottest it can be. I’ve seen videos of people with a similar issue but there usually is a clicking noise from the actuator that they hear behind the dashboard. I don’t hear any noise like that so I wonder if it’s a different issue. Has anyone else had a similar issue? If so how easy of a fix or if I brought it to a shop how much would it cost me?
