Access through the firewall/bulkhead for wiring. | Ford Explorer Forums
rwp1946
Nanaimo BC
97 Aerostar XLT 4L RWD
Hello all
does anyone know of any access holes or knockouts in the firewall/bulkhead in and around the steering column ? I need to run some wires from my brake control and trans temp gauge from the passenger compartment to the battery area .... also the trans temp gauge sending unit wire....
Now... in the past I have just drilled a hole through near the steering column where there is a blank space.... BUT ... I thought I should ask this esteemed group of knowledgeable experts if they know of any holes or knockouts I haven't found ....
Regards.... Ron
Previously drilled holes were on previous vehicles..... this is new vehicle for me and wanted to make sure I didn't miss any potential knockouts that I didn't know about.... will drill hole... and, yes, use grommet....
I'm not totally familiar with Aero's firewalls, but isn't there a cable for the throttle or something? I've always just poked a hole there and passed through:
That's an Explorer, but maybe there is a similar place?
Many thanks for the tip.... will take a look
There are places to go through, but they are limited to the number of wires, and gauge of the wires. If there are many wires, then it's best to drill a hole, and use a large rubber grommet. Approximately how many wires are you planning on snaking through the firewall?
