ACK - Rear Drum Brakes | Ford Explorer Forums
jtison
W Connecticut
'94 XLT/155 Kmiles 4x4
Well, I gotta admit I'm pretty frustrated. I'm just starting to reassemble the rear R drum brake. I'm early in the installation. Got the secondary shoe on, put on the primary (rear) shoe, and then realized I hadn't connected the parking brake cable to the lever. OK, remove primary shoe, and then I hit my brick wall for the day:
I can't get the **** spring retracted far enough from the "bullet" at the end of the cable to get it over that slot in the parking brake actuation lever. Serious: I only need about 1/2 inch.
Anybody got a handy hint for me?
TIA!!
jimbo74 said:
take the shoes off, and then put it on, it will stretch when you get some good leverage on it, make sure the e-brake is fully disengaged also
spin the star wheel all the way closed as well
Get everything hooked up first, and put the star/self adjuster assembly in last(adjust the assmbly all the way closed first). You will have to pry apart the bottom of the shoes, but it will work. A second set of hands would help.
I'm down to the backing plate, one shoe on. Figured I'd better hook the **** parking brake cable to the lever before I put the rear shoe on, or I'm gonna be in trouble :)
Thanks for all the suggestions. I think I'll start tomorrow when my hands and my frustration level are fresh.
