btennant
- May 28, 2015
- 1993 explorer
In December I changed my rear drum pads (ceramic) and brake cylinders, and almost immediately had issues with bad squeaking and very sensitive braking....only on the right rear side. I took the drum off several times, readjusted them, and verified with a mechanic friend that everything had been properly reassembled. However, as soon as I adjusted things and things felt and sounded better, within days the noise and over sensitivity returned. My friend suggested that possibly I had a warped drum on that side, so I replaced it on that side. Days later, the problems returned. Several times I adjusted the adjusting wheel while the drum was still on, it would get better, and again days later the problems returned. Next, I replaced the adjusting mechanism, it worked better for a few days, but the same problems returned. A few weeks later I replaced all of the hardware (springs, etc), and after about a week or so, the sensitivity and noise returned. It was if they kept incorrectly adjusting, so I returned the self adjusting mechanism to Advance Auto thinking it was bad, and reinstalled the second new one but that didn't help. When I replaced the mechanism, I also applied some anti seize to the contact points on the sides of the shoes (not on the part where it makes contact with the drum), and did a very thorough job of cleaning everything with brake kleen. For a few days it worked great (no noise at all and they felt perfect) and once again, the sensitivity is back and the noise is slowly coming back also. This past weekend (about 5 days after the second adjusting mechanism replacement and thorough cleaning) it had gotten extremely sensitive again where if I applied the brakes while driving real slow in a parking lot, the brake would catch very hard on the right rear and almost skid (this is the over sensitivity that I have been referring to). I adjusted it once more to loosen the pads away from the drum a little and that helped some. That was about 5 days ago. Now the sensitivity is not as extreme as it was last weekend, but still feels too sensitive and it seems to slowly be getting worse again. I am extremely frustrated and have spent crazy amounts of time messing with the right rear brakes. I read somewhere if you install the left side adjusting mechanism on the right side, then it can cause problems, but according to Advance Auto, I have the correct one installed. I have zero idea what else to try on my own, but based on how my adjustments to how tight the pads are to the drum seems to help, even if it is only temporarily, I would assume it is related to that. But the million dollar question is why it's doing that.....and why only on that one side. Any ideas will be greatly appreciated. Thanks in advance.
