dcsmrgun
- April 30, 2005
- Hamilton, Ontario
- '00 XLT
I'd like to add a circuit to power my new Sirius reciever only when the ignition is in the 'accessory' or 'on' position.
Right now I've got an add-a-circuit fuse tap powering a radio shack cigarette adapter under my center console, which I feed the power adapter to the Sirius into. The problem is that the fuse I tapped into makes a circuit that is always +12V regardless of key position, so I have to manually hit the power button on the radio. Its not a big deal but its the little things that count.
So did I just tap into the wrong fuse and there ARE some fuses which are accessory-on only, or are all fuses hot and the accessory-on break is made somewhere else down the chain? If not, does anyone have a good map of fuses and their state without ignition?
I could just tap into the radio harness, but I figured this way was cleanest. I really don't have a good grasp for the electrical system so I figured this add-a-circuit method would be best.
