RicanV84X4
- September 3, 2019
- San Juan, Puerto Rico
- 2010 XLT V8 4X4
Right up front I know enough to be dangerous with electric but am definitely a novice. I am installing a Blacksys dash cam system in my 2010 4.6 Explorer and I was planning on using a micro blade Add-A-Circuit into the fuse panel under the drivers side dash. I am using the Blacksys backup lithium ion battery system so I only need the power going to the dash cam/lithium battery when the cars ignition is on. I did some searching on the forum and it seems that splicing into the rearview mirror is the solution most people are using on the 5th generation explorers. Can anyone confirm that there are no fuses un the drivers side under dash fuse block that are only hot when the ignition is on in the 4th generation explorers? I have tried 3 fuses to no avail at this point. Really dont want to have to run a wire to the under hood fuse block. Thanks in advance for your help!
