myf16
- July 22, 2012
- northern California
- 96 Explorer XLT 4WD
I just completed this job on a low-rust (Florida/California) 1996 Explorer.
PB Blaster and a breaker bar were sufficient to remove the nuts from the U-bolts. The breaker bar alone probably would have done it.
The shock mounts do not need to be removed. Just rotate the U-bolt plate by 180 degrees about a vertical axis. I.e., twist the lower half of the shock relative to the upper half.
Don't remove the leaf springs from the shackles. Leave it attached at both ends. Raise the differential to create space between leaf spring and axle.
With about 2" space(not enough to insert a grinder), I used a Dremel cutting wheel to slice one side of the round head and make it flat. I sliced the other side flat too, but I think that's overkill. With one flat side you can put a vicegrip on it and it will not turn. I used an iron pipe to extend the vicegrip handle to 2 feet long. I put a 15mm socket and breaker bar on the bottom nut. Lots of PB Blaster. I would have tried a torch but I didn't have one.
On one side the nut came off. On the other side we snapped the bolt, which was just as good and a bit faster.
Reassembly was trouble=free, as described in the OP except that I avoided having to reattach the shocks and leaf springs. Total time was under 3 hours including lots of Dremel time and cleanup.
