add a leaf or shackles? | Ford Explorer Forums
explorerwhite93
King, NC
1993 XLT
ok i am doing the f 150 coil spacers for the front... but im not sure what to get for the back... should i get the add a leaf or shackles???... right now i have a 3 inch bl. thanks for any opinions later
Do you tow or carry heavy loads often? Are your leaves already a bit sagged? If so go with the aals. I'd personally go with the double aal, even if it makes your rear sit a bit higher; because your leaves are 10 years old.
i dont carry heavy loads and the most i tow is 3 or so 4 wheelers.... i was thinking the aal but will it lift the rear as much as the coil spacers will lift the front??? how much and where can you get the double aal
both from 4 wheel parts, single is around $30, 1-1.5"; double $75, 2-2.5".
aight thanks i think im gonna wait and go with the double..... i was just outside lookin at my leaf springs and i have almost no arch in them
and the stock shackles is probably like 65-70 degrees instead of 90
could someone send me the link to the add a leaf on summit... also is it the short aal or the long aal?
i personaly went to a local spring shop and told them i would like an aal and to rearch the original springs(that might only be possible for mono leafs?) for a total lift of like 3" they did a good quick job that ran me about 125 total
the 95-00 explorer sports had monoleaf, everything else ( 91-94) ( 01) have multileaf...
Just to let you know..
Shane
ya i have the mono liike N2MUDN91 said
