techboj
- July 19, 2005
- Surrey, BC Canada
- 99 Sport + 06 EB
My ideas aren't exactly new and I've seen it done before either here on another website but I figured somebody may benefit from the pictures.
Older Sony head units have an aux input that will only play when a CD Changer is connected. Sony HU's have a proprietary unilink connection that is a bit harder to activate using aftermarket solutions. The newer (maybe 2004 up) units have what sony call aux-lite. These act as regular inputs, however will render any Cd changer (or any unilink device) unusable.
The usual solution is to use a connector called an XA-300. This device adds more inputs to your head unit (and even a usb input from a laptop) but at $100 (from Crutchfield) its another way for sony to nickel-and-dime its patrons
If you have a cd-changer already installed or if you want an additional way to plug in your ipod or any mp3 player then there is an easy solution
First, the HU and CD-Changer are connected normally per instructions.
Then you split the connection for the audio outs of the changer with y-cables
Y-splitters on one end and a standard mini-jack on the other end
Plug in the y-cables to the sony changer
Incidentally, a sony cd changer fits in the factory CD-changer location in the console. No trimming was necessary and small brackets from thin material can be fabricated to hold the changer in place
Now comes the trick part. Create a silent audio cd and use that to replace one of the discs in the cd-changer. That way, when the changer switches to that cd, no audio will actually be fed to the head unit but the input is active because the unilink connection is triggered.
Now is the time to hook up your Mp3 player (Use the mini-jack from the y-splitter and plug it into the headphone jack of your mp3 player.
If your head unit supports CD-text or is capable of assigning names to your discs, you can rename the disk to Aux-Mp3 or something similar. This will make the integration look professional
