greg s
- February 28, 2005
- Gainesville,FL
- 1997 4wd sohc Explorer
Hi All, Its been a while since I have posted on here as the old Explorer has been rolling along. Its a 1997 4wd 4.0 SOHC that I have had since 1998 and it now has over 300k on the clock. While it was still under warranty, the local Ford dealer did whatever the TSB / recall? called for to fix the timing chain problem. About 3-4 years ago the timing chains started rattling on start up. Since then, I have been using the "crutch" of cranking it at WOT to build up oil pressure on the tensioners and stop the rattle and it has worked. I noticed a few weeks ago that it has a rattle that sounds like detonation. Its a lite rattle that happens only when accelerating from 0-45 and if you let off the throttle the noise goes away. Once it gets above 45 the noise is no longer noticeable. Not sure how long it has been doing this and I haven't been able to diagnose the noise 100%. Thinking bad knock sensor, timing chain problem, torque converter rattle, etc. I decided to stop driving it until I can figure it out to limit any possible further damage. The thermostat housing is leaking again and I am going to need to replace that. Both temperature sensors are corroded and green. I replaced the spark plugs as they had substantial wear on one side but that did not change anything. Looking for advice and suggestions on diagnosing it further. Thanks
