Aftermarket speaker install.. | Ford Explorer Forums
bndrulez
Phoenix, AZ
'00 Eddie 4.0 SOHC
I am trying to install speakers in the front doors that will run off an amp. How do I get speaker wire to the door through the stock harness tubing? Thanks for the help.
I used a wire coat hanger to feed mine with.
Yeah my friend has a snake, I was seeing if there were any tricks of the trade to make it easier. Thank you for your reply.
I have a 98 explorer...I was messing around the other day and you can pull the boot right out of the hole quite easily...getting it back in is quite easy also.
coat hanger is handy also
