Air Bag Light HELP | Ford Explorer Forums
Air Bag Light HELP
jayyzar
New Jersey
04 Mountaineer
I have a 04 Mountaineer and when I turn on the car the airbag lights up three times and shuts off. then three times again. it will do this 5 times and then stay on. Has any one had this issue before? does any one know how to fix this issue
I had a problem with the airbag light coming on. I cant remember how many flashes mine was doing.
My problem was under the drivers seat, A couple of wires coming from the floor up to an electrical connector on the underside of the seat. one of the wires was broken. So I unplugged the car battery turned the ignition on and off to try and dissipate any electricity in the cars system. then I had to splice a slightly longer wire onto the broken one once the wire was connected and battery plugged back in the light went off.
eveyone said dont play with the wiring myself as the air bag could go off. but no money means I had to do it myself.
here are some flash codes for ford airbags :)
Codes 12 to 14
These codes are started by a single flash of the indicator light, followed by a two-second pause. After the pause, the light will flash the number of times that corresponds to the second digit of the code. Code 12 (single flash, pause, two flashes) means that there is a lost battery feed. Code 13 (single flash, pause, three flashes) means that the airbag circuit has shorted to ground and Code 14 (single flash, pause, four flashes) means that the primary crash sensor circuit has shorted to ground.
Codes 21 to 24
These codes are signaled by two flashes, a two-second pause and the number of flashes that corresponds to the second digit. Code 21 (double flash, pause, one flash) means the diagnostic monitor is not mounted properly. Code 22 (double flash, pause, two flashes) means the safing center output circuit has shorted to battery voltage, Code 23 (double flash, pause, three flashes) means the memory clear circuit is improperly grounded and Code 24 (double flash, pause, four flashes) means there is a system disarm failure or internal diagnostic monitor fault.
Codes 32 to 35
These codes are signaled by three flashes, a two-second pause and the number of flashes that corresponds to the second digit. Code 32 (triple flash, pause, two flashes) means the driver side airbag has a circuit open or with high resistance, Code 33 (triple flash, pause, two flashes) means the passenger side airbag has a circuit open or with high resistance, Code 34 (triple flash, pause, four flashes) means the driver side airbag has a shorted circuit or one with low resistance and Code 35 (triple flash, pause, five flashes) means the passenger side airbag has a shorted circuit or one with low resistance.
Codes 41 to 45
These codes are signaled by four flashes, a two-second pause and the number of flashes that corresponds to the second digit. Code 41 (four flashes, pause, one flash) means the right radiator primary crash sensor feed/return circuit is open, Code 42 (four flashes, pause, two flashes) means the left radiator primary crash sensor feed/return circuit is open, Code 44 (four flashes, pause, four flashes) means the right radiator crash sensor is not mounted properly and Code 45 (four flashes, pause, five flashes) means the left radiator crash sensor is not mounted properly.
Codes 51 to 53
These codes are signaled by five flashes, a two-second pause and the number of flashes that corresponds to the second digit. Code 51 (five flashes, pause, one flash) means the airbag diagnostic monitor's internal fuse is blown, Code 52 (five flashes, pause, two flashes) means the back-up power supply has had a voltage boost fault and Code 53 (five flashes, pause, three flashes) means the front crash sensor has high resistance or the diagnostic monitor has failed.
Read more : http://www.ehow.com/list_7652177_airbag-light-codes-fords.html
Plenty of posts on the code 33 airbag subject
Mine will pop on all the time randomly, its been hit in the front but it wont flash, it'll just stay on, but when I turn on the truck/restart it its gone. sometimes the abs light will come on also, but go away if I restart the truck.
Mine did that 33 code. Slide drivers seat forward and look for the green connector mounted under the seat. Mine didn't have any wires attached to it, should be two. If missing, look for wires and pop out connector by pressing on top tab. Should slide out. I tool an angle grinder with thin cutoff wheel and notched ut about 3/8 inch in top and sides and then used a wire nipper to expose the pins. Soldered on two 6 inch pieces of wire onto the crimped section of the pins. Insulated it and added strain relief with a dab of hot melt glue. Then connected the wires onto the short FORD wires. Disconnect the battery for a few minutes before doing any of this.
