Air Conditioning Issue | Ford Explorer Forums
silverex
2010 Ford Explorer
2010 Explorer. Recently I've noticed that sometimes my air conditioning will stop blowing from the vents during acceleration like I have a vacuum leak. However, it will only do it a couple of times and then not do it again for a week or two, sometimes longer. Brought it to the dealer but it worked perfectly while there. They said to bring it back when the the problem got worse. My warranty expires in October. Does anyone have any ideas on what could cause this problem or if in fact it is a problem? Any comments are appreciated. Thanks.
It is possible for the engine temps. to be too hot when the AC cuts out on you. The vehicle is programmed to cut the AC under conditions when the vacuum is low and the engine temperature is outside of normal operating conditions (too hot). Don't know where you live, but under the right conditions I can get mine to cut out when traveling from Phoenix, AZ in 116F heat going up a 2000 ft climb out of the valley.
2010 Explorer. Recently I've noticed that sometimes my air conditioning will stop blowing from the vents during acceleration like I have a vacuum leak. However, it will only do it a couple of times and then not do it again for a week or two, sometimes longer. Brought it to the dealer but it worked perfectly while there...
Hi silverex.
I'd be more than happy to look into this for you. Please PM me your name, phone number, VIN, mileage, and dealer info, and I'll see how I can help.
Ashley
I've had the same problem with my 2007 V6 with manual air. I first noticed the problem a few months ago, when it was still reasonably cool, but my black Explorer got hot during it's sitting during church. So, that eliminates the heating problem.
I live in an area with many long hills and it too was intermittent. I checked all the lines under the dash (that I could reach with the glove compartment down) and found nothing loose. I then found that the grey line, which runs back out the firewall and to the front of the engine, had come loose. I reattached it and tied it up with zip-ties to prevent that happening again.
Everything seemed fine until a couple of weeks ago and it started again. I went back to the check valve and it was ok, but I decided to start the vehicle and see what kind of vacuum I had on that little line. There was vacuum, but weak. I followed the lines around to the plastic box where all the vacuum lines seem to start and it seemed to end at a ell shaped rubber adapter just in front of where the brake booster vacuum line goes. There were three lines going into this ell and all seemed tight. I decided to disconnect the ell and see if there was good vacuum there and there was. I looked inside the ell and could see the end of the larger line of the three, but one of the smaller ones (which did not come inside the ell) seemed to have a flap of rubber over the place where it should have come out. I removed this flap and pushed both of the smaller lines completely in to where I could see about 1/16 inch of the end inside the ell and re-installed the ell to the "box".
Rechecking the line near the check valve, there seemed to be an increase in vacuum and I have not had a recurrance of the problem.
Hopefully, I have found it, because I have experienced the "can not reproduce the customer's complaint" many times and know your frustration.
Good Luck.
