Airbag Code 12 | Ford Explorer Forums
Airbag Code 12
Equnoxe
Ontario
97' Exploder EB Edition
the dash light flashes like this
1 11 1 11 1 11 1 11
shopkey at my work says its code 12 and cause by low battery voltage.
my batteries are fine.
checked the fuses.
code reader at work couldn't pull anything..
any ideas? anyone had this problem
hi, i have a similar situation on my 2002 explorer, so far unable to cure problem, but when vehicle switched off i disconnect airbag wire connection under drivers seat for about five minutes & this seems to help for a while, i would be interested to how how you fix this problem permanently
i still haven't found a solution, im still tinkering with it :(
The module has a built in battery. Measure the voltage going to the SRS module. I don't know if this diagram will help since it's for a 95 Mustang, but it will give you an idea on how it works:
thanks, now i have somewhere to start poking around :P.
<--- not a fan of electrical problems.
do you have a picture of were this is located? and what it looks like
alright thanks
