Matt,
Thank you for all of the help. your information helped me locate and repair my sensor. As promised I took the pictures, but cannot post them because the forum does not give me an option. Anyone who needs them can email me (via this message) and I will get them to you right away. In the mean time here is a description; The sensor is located right in the middle of the front of the vehicle, in the opening below the front grille, directly in the middle of the opening between the fog lights (if you have fog lights). It is shielded above by a "ledge" and you must get down low and look directly into this opening to see the sensor. From the bottom, laying on your back under the front of the vehicle there is a plastic cover secured with 3 christmas tree style push pins. By removing these 3 push pins you can look up and see the sensor. The two bolts that fastened mine were #8 metric. I used a 1/4" ratchet and about 18" of extension to reach it from my position under the vehicle. Remove the bolts, unplug the sensor, plug in the new one ($68.00 at the dealer), bolt it back up. You are all done!
Hopefully this information will be helpful to someone else!
Regards,
Sno
