Originally posted by AdamCKach
Each time, except for the first time headlight switch, I replaced the bulbs or switch myself.
Adam,
Where did you get the bulbs to replace them with?
I went to a Ford Dealership, and they were unable to locate a part # for the bulbs. I also tried Torrie @ The Ford Parts Network, He also had no luck. The one place I did have luck was a local scrap yard, they had a 95-97 Explorer with the lights that I needed.
There are 5 Different Style/Shape bulbs.
Climate Controls = This is the same as the bulbs in the instrument panel
Rear Wiper = T-Shaped, Short, White Base
Fog Lights & Rear Defroster = Plastic Screw-in, Short Length, Black Base
4x4 Switch = Plastic Screw-in, Medium Length, Gray Base
Head Lights = Plastic Screw-in, Long Length, Black Base
(The Head Light Switch Light Bulb stays on when ever the truck is on, This is reason why most of ours is burned out.) Im thinking of re-wiring it so that it only comes on when the head lights are on such as all the other lights in the truck.
Right now I have a bulb that is for the 4x4 Switch in my Head Light switch so that I have the switch light up. So it will work, but i don't think that the light bulb from the Fog Lights & Rear Defroster would work due to it would be too short.
