Dave and Shirey
- June 3, 2024
- Saint Louis
- 2005 Ford Explorer Eddy B
2005 Explorer. None of the windows would work from any of the electric switches. I figured that if I replaced the module that controlled the child lock function, I would fix the problem. I removed the main control switch and replaced it. The windows worked. Then after putting the assembly back together on the door, nothing worked. I removed from the door and it still didn't work. I pulled the connecter back off the part and reconnected. It worked again. After waiting a half hour, I tried it again and again it didn't work. I removed the connector and put it back on and it worked again. I reassembled everything again and when I attempted to lower any of the windows, nothing worked. Any ideas on what I might try next?
