- January 27, 2002
- Texarkana AR/TX
- 94 SAS sport
Check the wheel bearings on the trailer. One or more bad bearings will allow a tire(s) to camber in slightly and cause the "trailer death wobble". As long as you've got about 500lbs. tongue weight with that setup (it looks like you do), it shouldnt be an issue. Have you tried the trailer/car behind anything else? Im thinking its the trailer..... either a bad bearing or an axle out of square. Try pulling the trailer behind another truck and see if it does anything.
Take that money others have suggested on load distribution stuff and get brakes on it first.
I have towed with my 5 liter (before it was lifted) many a mile and never had a problem. Several times with more of a load than what you are towing.
