Ryon40
- March 30, 2009
- Cincinnati, OH
- 1998 Explorer Sport 4x4
First off Ill explain what has lead to my truck dying...again lol. So we have had some snow here and I decided to switch my 4x4 high on, I noticed when slowing down and turning the wheel left or right itd make a groaning noise and sometimes shake, I blew that off figured it was snow (still dont know if it was or if its normal). Second after about three to four days driving with 4x4 high on my battery light came on and lights (headlights as well as interior lights) dimmed to about half the normal brightness then the battery light would go off sometimes stay on but the lights would go back to being bright (I did install a message center and led conversion on the inside as well as a reverse glow inst. cluster, but all is wired correctly). So I switched 4x4 back to auto and the problem was fixed..for about two days.
After this started happening I poped the hood to check the battery terminals and all was good there. Drove down the road again and then noticed my ''ABS'' light came on, then went off, and came back on. Next my radio shut of along with message center display, although the button lights were still on as well as the rest of my lights but very very dim like the lowest setting on the dimmer switch. My overhead console with the temp and everything started reading -188 and filled in the N S E W. Then it just shut down it was still running but shut down I would press the gas, no movement but when I let go Id putt forward. I was going up a slight incline and the X couldnt make it and died.
Soooooo I dont think its the battery because after about two minutes I could turn my keys to the option setting and have all lights and radio as bright as they would normally be. Tried to start and it would just click, although after letting it sit for about five minutes itd start but would only drive so far.
Any ideas?
Thanks alot!
Any ideas?
Thanks alot!
