Mike65
- December 31, 2013
- Horsepasture, Virginia.
- 00 Ranger 4x4, 99 Sport.
I drive our spare vehicle our 99 Sport usually once a week to keep it running & the battery charged. I also like using it when I do the food shopping because it is easier to put groceries in the back better then in behind the rear seat of my 05 F150 regular cab. Last Thursday I go to take it to work with me & I get less then 1 mile from home & notice the wipers going slow & the headlights look dim so I look down at the gauges & the charging gauge is reading very low so I swing around & go back home to get my F150. After coming home from work & get out my multi meter & check the charging system & it is only putting out 11.1 volts, time to replace the alternator. I ordered a reman from Rockauto & it arrived yesterday. It took me less then 1/2 hr to install & get the serpentine belt back on. Start it up & the gauge now is at the 1/2 way point on the gauge. I tested the charging system with my multimeter & now it is charging at 14.4 volts, problem solved.
