Willard
- March 16, 2007
- Bloomington, Indiana
- 04 Ranger Edge
Well, the past couple days I have had a problem come up a couple times. The charging light has come on intermittently, usually during hard acceleration. I have also noticed the battery light doesn't come on when starting, and I have realized it hasn't since I can remember. Another issue that has been for a very long time, is that it charges kind of high, like 3/4 the way up the volt gauge on the dash. It stays there all the time, unless I am sitting at a stop light with the lights on, and the heater cranked up all the way, when it drops down to the middle. Upon reading I have found I might have a bad voltage regulator. It is also possible the cable need replaced, as they are the original ones. There are no actual charging problems, it cranks fast all the time, and everything works like it is supposed to. I just think I have an arising problem here. I just want to know what the problem could be, I don't want to replace the alternator, it seems to work fine. The drive belt it newer and properly tensioned. Any thoughts? :scratch:
