Currency
- September 11, 2009
- Bedford Indiana
- 94 XLT 4x4
As the title says, another day and another problem. ABS related this time.
As I have stated before, I have a bad upper ball joint on my front right side and my alignment is off, and the right radius arm and bracket need replaced.
Now whenever I am turning right really slow under 5MPH my abs starts kicking in, mind you every time I was on black top when this happened. When I back up and touch the brakes, the abs kicks on but at any time mentioned above the ABS light stays out.
Now if I take a hard right turn braking or not, the ABS light will come on.
Hey guess what? I think it has something to do with the front right ABS sensor or something else related to the ABS on the front right.
Yeah, now I know I have to fix the above mentioned things. Little time, no money. I do have the ball joints but not enough money to rent the tool to press them in.
So, tell me what you all think. I think I may know and have mentioned what I believe is wrong but again, not sure. Very odd abs issue in my opinion. :
