Another Door Lock Problem... | Ford Explorer Forums
tk89123
Las Vegas, NV
'95 XLT
I've already tried to search and can't quite find my problem. When I either use the fob to unlock or the autounlock unlocks my doors on my 95 XLT the drivers door lock cycles 6 or 7 times very rapidly. Any recomendations as to where the problem is would be appreciated.
95 XLT 4x4 TT war153 shackles 158k
perhaps the unlock relay in the rear cargo panel has a problem (chatter) or possibly a bad feed (loose wire) from the PATS module which sends its signal to the unlock relay. If you unlock button at all door / cargo positions is "stable" then more probably the wiring to the PATS or the module itself.
Thanks for the response. I'll mention this and any others when I take it in for service.
Bump
