Another Engine Code, SAME ONE! | Ford Explorer Forums
00blkexplorer
Los Angeles
00 Explorer XLS
Okay this is probably the third time ive gotten that same code. P0305, misfire in cylinder 5. The engine starts getting real rough and "jerky". I replace the spark plug the last time and saw the spark plug to be cracked. Now the same code popped up again. What can be happening? I'm totally lost.
I recently changed the plug wires. They are under warranty. I will change them all out and change that damn spark plug again. Hopefully it doesn't do it again.
the missing cylinder error codes is how the symptoms started when I needed the air intake o-rings replaced. my 'trusted' mechanic said this was a common issue, at least on my 99 but I can't say for sure if it applys to 00s. also, with the o-ring prob the missing and rough running gets considerably better when the engin warms up (o-rings soften and seal)
