Blind
- December 14, 2004
- Half Moon Bay, CA
Rough idle, engine code 0300..ideas?
Randomly the idle on my truck is perfectly smooth, then at random stops it's really rough, and the voltmeter needle dances around too.
I just:
changed fuel filter
changed plugs (autolite platinums, gap set to .052)
cleaned MAF sensor wires with electrical cleaner
I then hooked up my code reader and cleared the code, previously the code my check engine light gave me (I forget the #) was for a "random/multiple cylinder misfire" and I could see why, my plugs that came out were all around .082 gap.
The code it spit out tonight was for the secondary o2 sensor? How would the o2 have an effect on idle? My thoughts are it threw this code because of the unburnt fuel from the bad spark plugs and the o2 was just reading garbage air from the misfiring.
I test drove it a few minutes ago and it did the rough idle crap at a stoplight again, then the next stoplight I came to it idled perfectly smooth
any thoughts?
It's the exploder in my sig, 1996 4.0 OHV automatic 2wd, just turned 98k miles.
I just:
changed fuel filter
any thoughts?
