briwayjones
Manual Master
- December 11, 2003
- Location
- Maryland, USA
- Eldersburg, MD
- 2000 Ford Explorer XLS
I've been having a low idle problem on my 2000 X for a while now that is getting worse. It doesn't matter the temperature or whether the vehicle is warmed up or not. At first when stopping at a stop about half the time the idle would drop to about 400RPM. Now it's getting worse and most of the time the idle will drop all the way down to about 200RPM.
Now here's the twist. It was in the shop twice recently to fix a CEL which I was hoping would fix the idle. The CEL was because of a vacuum leak because of a bad upper intake gasket which is now fixed. So it was vacuum tested and everything and shouldn't have any other vacuum leaks. The IAC and MAF have both been cleaned. I'm pretty sure the plugs and wires are fine there are only about 20,000 miles on them.
So what else could this be?
