moriver
- April 27, 2008
- Kansas City
- 2005 Explorer
Hello all I wanted to ask about a rattle I have in my 4.0 The rattle only makes noise when heated up to temp between 2 and 3K and of corse changes with the engine RPM. I pulled the drive belt off hoping but nope...noise still active. Now some background. The truck is a 05 Explorer with 157K and just last year had chains, guides and tensioners. I had a set of lifters so I pulled the covers and did the lifters I figured what the heck. While there I checked the chains and guides. Front was good and tight. The rear chain had some slack in it. I turned the engine over and the adjuster promptly tightened up the chain and the slack was gone. I used my scope and looked over the rear guides and found no cracks. So other than any normal wisdom I was wondereing if someone could tell me
1-Should that rear adjuster be totaly colapsed like that until the engine is started?
2-Knowing the engine only makes noise when warmed up whats that telling me and what does a failed tensioner cause??
Much thanks, you all helped me out last year with my chain job and I am thankfull for whatever help you can give.
Scott
Scott
