Another SOHC timing post | Ford Explorer Forums
ipwizard
Peoria, AZ
'01 XLT
Getting ready to tackle this project. Can you guys check my list and let me know if there is anything i'm missing?
I'm pulling the engine, so im going to do as much to it as possible while its out.
SOHC OTC Tool Kit OTC-6488
Jack Shaft Chain
Jack Shaft Chain Tensioner
Jack Shaft Chain Guide
Left Side Timing Chain
Left Side Cassette (This includes, or is the tensioner right?)
Left Side Chain Guide
Right Side Timing Chain
Right Side Cassette (This includes, or is the tensioner right?)
Right Side Chain Guide
Right Side Plug (for access to rear jack shaft sprocket bolt)
Oil Pump
Valve cover gaskets
Timing cover gaskets
Upper intake gaskets
Lower intake gaskets
Timing cover seal
Rear main seal
Rear tranny seal (seeping)
Sprockets if there is any damage, I'm pretty sure mine has jumped teeth because of the excessive pinging after a really nasty noise a couple months ago.
Depending on wear might end up changing the rod bearing, and I suppose the main bearings also.
LOTS of time, money, and patients.
I'm not sure about the oil check valve, dont know if I need it yet.
I have collected a few part numbers form this site. I can work with my Ford guy on the others.
Anything i'm missing?
