another tcase question | Ford Explorer Forums
Joshh
Princeton, wv
95 Explorer Sport
another tcase question(4405)
i have a 95 X, 4.0 5sp(m5r1) with the 4405 tcase. A few years back my tcase went out and i bought one off ebay. Apparently i bought the wrong model because my speedo wont work. is there some way to fix that problem?
not at all or the wrong speed?
Was the replacement out of a 95? My guess would be that the speed sensor is not picking up for some reason... but 4auto probably doesn't work either, does it?
-Joe
dosent work at all....the garage said they couldnt hook it up. Like the connections were different i guess.
What year and model did the replacement transfer case come out of?
i have bought a
8ca
44-05-000-010
F87A-74195-CA
no idea what was in it to begin with
You purchased a t case from the wrong year, and the speedo setup changed. Sell the case you have and make sure to get one from a 95.
If my memory serves, the 95 and 96 t-cases have the rear shaft speed sensor. In 97 they went to the CV-joint front driveshaft, so the front output flange is different (and it's not just a matter of swapping one for the other either). For 98, they dropped the rear shaft speed sensor. So, for a 95, you need one from a 95 or 96 for it to be a plug and play installation.
-Joe
